Ok, I got a funky water supply from the KY river. One terlet in the house, gets a nasty scum in the bowl that is mineral or iron in nature.
We can clean it and within a day or so, it begins again. I do have this one hooked up with hot water for the sweaty tank in summer syndrome, so maybe that contributes.
We don’t drink the city water, and I’ve yet to install the Whole House sediment filter…the water heater gets flushed once a yr. On my second set of elements in 7 yrs.
Question I have is, what is one the better bowl inserts / cleaners that don’t make blue water? The lid is always down and the door almost always closed, so no dogs drinking outta it.
Oh, pipe is poly from the meter, and copper after it enters the house..new in 04. Cold water terlet upstairs with almost the same usage hasn’t the same problem as bad.
PROUD MEMBER OF THE ” I ROCKED WITH REZ” CLUB
Sphere: Clorox makes a very high chlorine tablet about the size of a hockey puck to plop into the tank. No color. Just gives a faint chlorine odor. Works! BTW: don't touch them w/ bare hands while opening pkg to insert into tank.
Don
The Glass Masterworks
"If it scratches, I etch it!"
Thats what I'm talking, something like that. We've never used anything cuz of pets, but this is getting old scrubbing the bowl almost daily.I recall seeing a stickum under the rim type, I had concern about the float and stuff in the tank being affected. I already have to swap them out fairly often as is.http://forums.taunton.com/n/docs/docDownload.aspx?guid=CAFDEA31-902C-4F75-9AA2-4DD5EBF749CB&webtag=tp-breaktime
PROUD MEMBER OF THE " I ROCKED WITH REZ" CLUB
Those suckas really work. we use them. They last a long time & totally dissolve.They come 6 in a green box. Called Clorox Automatic Toilet Bowl Cleaner. They have enough chlorine in them that they precipitate out iron in the tank - keeps the bbowl from getting a rust ring. Toilet should be flushed at least once per day.DonDon Reinhard
Not sure I'd want to pump clorock into my septic tank.
Jesus , I can't even spell Clorox!
Edited 12/3/2009 5:59 pm ET by Henley
See? dats why I asked. I knew there was one that went under the rim, and was less hazardous.http://forums.taunton.com/n/docs/docDownload.aspx?guid=CAFDEA31-902C-4F75-9AA2-4DD5EBF749CB&webtag=tp-breaktime
My momma has some pretty nasty pizzwater coming outta her well. Called the local Kinetico thief and Presto! Now it's drinkable! Course, that did cost some money...
I don't want to drink it, just flush with it. All the while not having my terlet look like an outhouse.Spheramid Enterprises Architectural Woodworks
That problem, too, went away. Before, like you describe, the crud would build within hours.
It really makes the can look much cleaner.
That is the oddest toilet I have ever seen. Is it European?
Mike
Small wheel turn by the fire and rod, big wheel turn by the grace of god.
I'm not a pean, are you apean?I's TRYING to get it more sized down, but having not much luck.
It is kinda cool and a step up from my monochrome original.http://forums.taunton.com/n/docs/docDownload.aspx?guid=CAFDEA31-902C-4F75-9AA2-4DD5EBF749CB&webtag=tp-breaktime
Joe H
Hey thanks, lets see if FFOx will play nice, otherwise I go back to IE.
Fingers crossed.http://forums.taunton.com/n/docs/docDownload.aspx?guid=CAFDEA31-902C-4F75-9AA2-4DD5EBF749CB&webtag=tp-breaktime
http://forums.taunton.com/n/docs/docDownload.aspx?guid=46B35A4C-CD5A-41A0-BFFA-&webtag=tp-breaktime
Mine doesn't work at all, yours works if I click it & open in new window.
Mystery of the World Wide Web.
View Image But I can copy & paste from the first one.
Joe H
Edited 12/3/2009 7:28 pm by JoeH
Edited 12/3/2009 7:30 pm by JoeH
I got it! Just need flames like Dino now..LOLhttp://forums.taunton.com/n/docs/docDownload.aspx?guid=46B35A4C-CD5A-41A0-BFFA-2F4A29FA1894&webtag=tp-breaktime
It worked a minute ago,,I give up.http://forums.taunton.com/n/docs/docDownload.aspx?guid=46B35A4C-CD5A-41A0-BFFA-2F4A29FA1894&webtag=tp-breaktime
Try dis again..thanks again.http://forums.taunton.com/n/docs/docDownload.aspx?guid=46B35A4C-CD5A-41A0-BFFA-2F4A29FA1894&webtag=tp-breaktime
"so no dogs drinking outta it."
Ah, pas de chiens! Zut!
Perhaps this is Monsieur's problem! Zee dog's remarkable resistance to harmful, uhh... how you say eet, bacteria, non?... can be most successfully transferred to zee Doobla-Vay Say, as we call it here in La France.
Oui, peut-etre les chiens may suffer from un peut de, uhh... how you say eet,... Goat Blast?... Barking Spiders?... Les Farts Gros?...
(pardonez-moi mon Anglais, je ne le parle-pas bien).
Comme il dit, le chien est man's best ami, n'est-ce pas?
AhshKay
Tu est bon homme Charlais Brown.Spheramid Enterprises Architectural Woodworks
I see you speak Montreal. If you don't know the word in one language, just switch to the other.
I have the same problem with my well water. My plumber says it's from the high mineral content and hardness of the water. I've tried every bowl insert made and none helped. I can't even get the buildup off the bowl with acid anymore.
My well or Spring would be worse, this is 'city' water, but from the Ky. River.We have lots of Limestone, makes strong race horses, but terrible water.I think this gunk is fish poo.http://forums.taunton.com/n/docs/docDownload.aspx?guid=46B35A4C-CD5A-41A0-BFFA-2F4A29FA1894&webtag=tp-breaktime
Same here, lots of limestone and sulfur. I see survey stakes out by the road. I hope it means city water which is still undrinkable but at least relatively clean.
The hot water doesn't help. A sediment filter WOULD help.
But it would be good to know what's comprising this scum. Could be hard water, could be iron, could be organics, could be some sort of fungal growth or some such. How you fix it depends a lot on what it is.
What color is it, and how thick does the scum get?
(And just a thought: If the flush valve is slowly leaking then that will cause scum to build up much faster in the bowl.)
Looks like Brown alga actually. Can be a film all under the water level, coating the bowl. A male can make it slough off with a "good stream" and good aim..LOL
Thin kelp like growth.
May be tannins from leaves and such. Does the problem vary by season?
This country will not be a permanently good place for any of us to live in unless we make it a reasonably good place for all of us to live in. --Theodore Roosevelt
No, not really.I fear when I install the filter I'll be buying new cartridges by the case.
Possibly.
Howd'ja do it?
Joe H
I don't know
LOLBut Thanks!http://forums.taunton.com/n/docs/docDownload.aspx?guid=46B35A4C-CD5A-41A0-BFFA-2F4A29FA1894&webtag=tp-breaktime
What the?Some one is messing with me...
I used to use those bleach tablet until I got tired of replacing rubber parts. I found a device that just puts the bleach water in the bowl and not in the tank. It is made by Fluidmaster and you can get just clear or blue replacement cartridges. It works pretty good and installation is a snap. Just do a search for Fluidmaster 8300.
Steve
