Want to know if I could supply a remote panel with
a GFCI breaker (50A feeder) and then use AFCI
breakers for the bedroom branch circuits? My
inspector has been helpful with the pragmatic,
but has stumbled with design(?). Another
question he didn’t know was having GFCI
protected recp’ts in shop(which is on the same
level as garage, concrete floor, at grade level,
(of course); but I am putting in a raised wood
floor.
Thanks, Ed
I would supply the remote box with regular 50A breaker (non-GFCI). Then at the remote box, each individual circuit can have a GFCI or AFCI as needed.
You get out of life what you put into it......minus taxes.
Marv
I think having an entire panel on a GFCI poses too many opportunities for nusiance trips.
I don't see any advantage to doing this and the dissadvantage of too many false trips.
" Another
question he didn't know was having GFCI
protected recp'ts in shop(which is on the same
floor. "
Here is the wording from the 99 NEC.
Dewelling Units - "Garages anbd also accessory buildings that a floor located at or below grade level not intended as ahbitable rooms and limited to storage areas, work areas, and ares or similar use." Require GFCI protection 120 volt circuits.
How if that floor is above ground level (does not say how much) or you put a bed in it them they are not required.
Also if this is not part of a "dewelling unit" they GFCI's are only for bathrooms and rooftops.
Thanks all- I think that I will put in some j-boxes to avoid the GFCI-AFCI dilemma and remove the switches from the bedroom for the outside soffit lights and recepticles(Christmas lights).
Bill- I am doing a printout for the inspector, thx
Ed
