I’m remodeling a historic home in Kansas City Missouri. This home has double brick exterior walls. My designer is suggesting removing the plaster and exposing the brick on the interior of the home. My concern is the energy efficiency upon removing the plaster. Are there any other options to consider.
![](https://images.finehomebuilding.com/app/uploads/2024/07/23115115/FHB-Pod-642-feature-scaled-thumb-16x9.jpg)
Listeners write in about attics, foundations, and dodgy electrical devices. They ask questions about trusses, wet ceilings and siding installs.
I guess you need to clarify for me whayou want to know.
The plaster is adding almost no insulating value. I don't see how you are worse off after removal.
-Rob
*I would think twice before removing the plaster and exposing the brick... not because of heat loss but because: (1) it is a historic residence and (2) while quaint for a while, exposed brick is a real mess on a wall. Brick walls were generally not meant to be exposed when the homes were constructed, so it sounds like your "designer" doesn't know "restoration" from "reinterpretation." Brick, expecially "low-fire" soft brick is extremely messy and rough. You will be finding red grit all along the wall, and dust/fuzz attached to the wall over time. Sweeping the wall will simply erode more brick.I'd think again about the project. Is the plaster THAT bad?
*I'm with Larry on this -- not only was the interior brickwork never meant to be seen, so it will be to a far lower standard than the face brickwork, but there may be service chases down the walls.BTW, sealing the brickwork, once exposed, to stop dust generally guarantees that you can never re-plaster!
*The plaster may add no real insulation, but it does help control drafts. You will never plug all of the draft holes in the brick, even after repointing all of it.
*Rein,I disagree, solid masonry walls are some of the tightest you can build, even if they are old and have some cracks. The cracks seldom go all the way through. All I can say is what I've seen with the blower door.Brick and fieldstone houses have very tight walls, the problem is usually the old ceilings and windows.-Rob
I'm remodeling a historic home in Kansas City Missouri. This home has double brick exterior walls. My designer is suggesting removing the plaster and exposing the brick on the interior of the home. My concern is the energy efficiency upon removing the plaster. Are there any other options to consider.
