Entry Lock Sets for Oversized Styles
joewood | Posted in General Discussion on May 3, 2005 10:36am
I’m hoping someone knows a source for nice Entry Locksets for custom exterior gates that have frames thicker than 1 3/4″ ?? Or maybe just a reccomendation of where to go to look for nice gate hardware.
  1. jrnbj | May 03, 2005 11:57pm | #1
    Been a while but if I recall correctly most of the higher end brands (Schlage, Emtek) products can be had to fit up to 2 1/2 " slabs....just longer tabs, & screws.....
  2. frenchy | May 04, 2005 12:04am | #2
    Joe Wood,
     Or you could do as I intend to do with my 4 inch thick doors,,  carve a relief into the doors (with a router) thus setting the handles flush with the surface.
  3. calvin | May 04, 2005 12:45am | #3
    Joe, this is normal, run of the mill hdwr with thumb action, usual flipper bar on the other side.  However, it works to 2-5/8's depth.  Nothing special about this Stanley gate hardware, but its there if you need it.
    I hope you do find something different and you can post it here.  Seems you never find something easily for that elegant application.  I would have liked to have found something that looked good both sides, but in this case it matched what was already on the other openings.
    Quittin' Time
    1. joewood | May 04, 2005 01:34am | #4
      ay yi Yi ! You mean any higher end lockset will do with longer screws etc !
      OK, that's a Great tip. I'll start lookin into that.
      Hopefully someone has a link for some upper-end gate hardware ! (that I haven't already found).
  • Smarter Stop Block
  • Square Walls Solo
  • Deck-Board Pry Bar
