Dependent upon my clients approval(a very progressive contractor) and the construction schedule. I will be involved in the process of a full/fledged/no holds barred radiant floor heat system in Eureka, Ca from 12/7 to 12/13/99 in No. CA.
If my client agrees, I would like to extend anyone who can make it, an invitation to come have a look-see. Again, I reiterate, DEPENDING UPON MY CLIENTS APPROVAL!!!
This project is residential, 10 zones, injection pumping based on outdoor temperatures with a water heater as the heating plant. There will also be a gyp-crete poured floor underlayment when all the tubing is installed.
I’m not promising anything here mind you, but if you are in the Northern CA area and respond via email before I leave on Sunday(12/5), I will try to set up an experience well worthwhile.
Jeff -
I would love to come and take a look-see but I'm afraid I don't have time to fly to CA - sounds like fun, though.
I'm not promising anything here mind you, but if you are in the Northern CA area and respond via email before I leave on Sunday(12/5), I will try to set up an experience well worthwhile.
