I have to repair two sections on an exposed aggregate sidewalk. I would appreciate input from anybody that has any experience with this style concrete work. Thanks all.
Hire a pro who regularly does aggregate flat work, and don't espect a perfect match. The results will depend upon a number of factors extending from who mixed what at the plant on a given day to the curing/washing process used as the project nears completion. You can help by cleaning (i.e., power washing w/some bleach) the adjacent surfaces before getting an estimate... this will assist in determining the material and finish for the repair work.
Good luck, Steve
*Rich,This is for pro's only. Don't try this yourself unless you've done it for years or are prepared to tear it back out and hire a pro.Ed. Williams
CAN ANYONE EXPLAIN THE PROCESS.
Well, I was going to type an explanation, but being lazy, I mean smart, here's an excerpt form a 10/96 JLC article by Dennis Golden:
b EXPOSED AGGREGATE
An exposed aggregate finish has a lot
going for it. The uniformly exposed stone
surface is attractive, the finish is relative-ly
easy to produce, and the cost is often
comparable to that of a standard slab.
b The Mix
The appearance of an exposed aggre-gate
slab depends entirely on the stone
chosen for the concrete mix. Different
concrete producers get their stones
from different sources, and the varia-
tion in color can be significant. The size
of the stones will also affect the finished
appearance - the larger the stones, the
coarser the texture. Most concrete pro-ducers
offer aggregate in sizes from 3 /8 to
1 1 /2 inches, and an exposed aggregate
mix typically has 5% to 10% more
stone than a standard mix.
Before agreeing to provide an exposed
aggregate finish, you should discuss the
appearance of the aggregate with your
clients, and note any preferences they
may have. If it's important that their
slab looks like the one next door or
matches existing work, make sure you
know the size and source of the stone.
b Seeding Is an Option
An alternative to using the "straight"
mix from the local concrete company is
to augment the mix with stones of your
own choosing. If your customer wants a
particular type or size of stone incorpo-rated
in the finish, they can be "seeded"
into the concrete surface. The stones
are tossed out on the freshly poured
slab, floated into the surface, and then
re-exposed when the concrete starts to
set. Seeding is a tricky procedure and
requires a finisher with a good eye as
well as a steady arm.
b Timing Is Everything
An exposed aggregate slab is poured
and floated in the same manner as stan-dard
slab. After the final floating, the
procedures change. Using an ordinary
spray can, a retarder is sprayed evenly
over the entire surface, the same way a
curing compound is sprayed. This slows
the set at the surface of the slab. A sugar
water solution of 4 ounces of sugar for
every gallon of water makes an accept-able
retarder.
The concrete below the surface is
unaffected by the retarder and sets at a
normal pace. When it's time to wash
away the surface cement and expose the
aggregate, the firmer concrete below
will hold its own against the water spray.
The slab is ripe for exposure when a
16-penny nail will no longer penetrate
the surface (apply the same pressure as
when writing with a pencil).
Exposing the aggregate is a two-per-son
operation. Starting at the high side
of the slab, a hose set to a fine spray is
held a few feet off the slab, and the sur-face
layer of cement is washed away. A
second person gently brooms back the
sand and cement that accumulates in
front of the spray (Figure 5).
b A Sealer Enhances Appearance
It's a good idea to apply an acrylic
sealer to an exposed aggregate finish.
The sealer will enhance the appearance
of the exposed stones (it creates a "wet"
look), and prevent the slab from absorb-ing
moisture (important in frost-prone
climates). The sealer, available from
W.R. Meadows (P.O. Box 543, Elgin, IL
6012; 800/342-5976), costs between
$16 and $20 per gallon and can be
applied with a hand sprayer. Coverage is
approximately 200 square feet per gal-lon.
The sealer should be reapplied
every year.
b Plan for Runoff
Runoff water from an exposed slab
project is nasty stuff. When handled
improperly, the diluted cement paste
can "burn" vegetation, instantly discol-or
a blacktop driveway, and get you in
big trouble with the downhill neigh-bors.
If necessary, the wash water can be
contained with dirt or sand dams, and
the mess can be mucked into a wheel-barrow
for on-site or off-site disposal.
Just be sure you have the necessary
materials on hand before the pour.
