anyone have ideas,information, experience etc. pertaining to insulating living spaces while keeping the framing exposed?
thank you
yes... fake it.... modern houses have so much stuff in the walls it's almost impossible to leave the framing exposed
cover the real framing and add "exposed framing " on the interior
I ended up with exposed 6x6 posts in the corners and midpoints in a small (400 square foot foot print) boathouse/guesthouse. 2x4 studs, R-13 insulation. sheet rock sets about 1" recessed. you can get better insulation if you want. not really exposed framing
Tell us more about what and why
i am disassembling an old house (1918) and just really kind of like the feel of exposed framing, the attached photo is a good example of what i'm thinking of. really i've just been considering it for the attic (finished). I've thought a little bit about structural panels - do they make for awkward trim when the building has exposed rafter tails?
Your photo was not attached. Try again.Sometimes you need to be creative with trim. It can take more than normal time
Take a look at this site: http://www.backwoodspostandbeam.com. These folks have designed a simple wall and roof panel system that includes the interior V-groove pine planking, but not the exterior components (foam insulation board and exterior sheating/siding). We looked at their kits last summer for a possible camp up in Maine, but haven't been able to get back to it - too many other projects like a kitchen to finish in our primary house in RI and a fixer-upper that we bought in Maine last fall. If we ever get around to building a cabin on our land in Patten, ME, though, we'll probably go with one of their kits.
Bob
thanks a lot.
really like that site. i spent one summer in maine and since feel good about anything that comes from the state. i sometimes look at the mainebarncompany site just because it all seems so nice. anyway, i am going to look into that paneling system. thanks
sorry that wasn't clear - i meant the photo from your first response. it is what i had in mind.
thanks
Well, part "faking it" makes sense--a little conduit here and there is not so bad. Start adding in ductwork, phone wires, cable coax, cat5/6 wire, the "romance" kind of gets a little lost. (3way switch legs are a lttle less romantic, too.)
Ok, having absorbed all that, and thought of several work-arounds; consider that most essential of residential mechanicals: Plumbing, especially DVW. It's real hard to marry "romance" to a 3" stack (assuming you find a paint to cover the primer on all the joints).
This does not mean you can't use a very skinny wall for your partition walls, and "flesh" them out with "exposed" board on stud details.
You do have to consider the finish of the finsihed goods, though. Sometimes, a couple of coats of paint just aren't enough to go over finger-jointed framing stock.Occupational hazard of my occupation not being around (sorry Bubba)
will7
It's called timberframing, go to a sawmill and buy beams and put them inside.. if you want the real benefit attach SIP's to the exterior of beams (ask if you don't know what a SIP is)..
