Good Morning to all.
My client wants to use a ext. plywood on a outside deck and cover it with ext. carpet . I dont think this is a good idea. Any thoughts from anyone?
Keith2
The electrical hookup is only one part of the equation; when installing a hot tub, there are a number of key requirements to keep in mind.
Where is the house? Big difference if you're in Arizona or Seattle. Is the deck elevated? How far? Is the deck roofed?
And you would get better responses if you moved this to "Construction" or "General". This section is for Monday morning quarterbacks to give cheap advice on how to better run this forum.
Whenever you are asked if you can do a job, tell'em "Certainly, I can!" Then get busy and find out how to do it. T. Roosevelt
Edited 9/8/2004 9:03 am ET by Ed Hilton
I am in San Antonio Texas. The deck is outside and not coverered . Also it is by a swimming pool.
San Antonio ... I've heard of that place. If the deck slopes enough to let the water run off, it might work. But you.re next to a pool, so thsat means that the ply will get wet frerquently. Probably not a good idea. Why does the client want carpet?
Use a EPDM membrane over the ply.
Jon Blakemore
besides the membrane, use all treated lumber including the plywood, a decent amount of slope and avoid places where water can get caught up in the cracks and stay wet after a rain storm. let it drain through...
built the way the customer proposes it, he needs to be prepared to replace it every five or six years
