Exterior corner framing
gdcarpenter | Posted in Construction Techniques on March 10, 2006 04:52am
Sitting here with too much time on my hands, SWMBO out of town.
What if:
________
!________! <— 2 x 6
! ! ____
! ! !____! <— 2 x 4
!_! !_!
You preframe all your exterior wall corners like the above diagram, with it’s own short bottom plate, no top plate, and locked it all together by placing 1/2″ insulation board between the inner & outer members.
Prevent that solid mass in the corners with zip for insulation. Also, with standard construction, if wide outside corner boards are used there’s no stud to nail the siding to at the ends, which problem this would solve.
You could then frame ‘normal’ walls with a stud on each end to slide into the space between the existing ‘corners’, tieing them in with the top plates.
Just too much time on my hands tonight.Let’s not confuse the issue with facts!
Edited 3/9/2006 9:05 pm ET by gdcarpenter
Edited 3/9/2006 9:06 pm ET by gdcarpenter
    razzman | Mar 12, 2006 05:18am | #1
    bump
    'Nemo me impune lacesset'
    razzman | Mar 16, 2006 03:04am | #2
    Is that some type of a new form of Morse code?
    be ...---...  (out of whiskey)
  • FHB Podcast Segment: Patching Drywall Near a Shower
  • The Unabashed Maximalist
