Should I install an exterior door at subfloor level or set it up 3/4″ for the future hardwood? Is there a standard for how tall the interior door sill sticks up?
Thanks for any advice.
The best tool for straight, splinter-free cuts is made even better without a cord.
That depends on the height of the door sill and the height of your finish flooring. Also would you like to put a small carpet mat that the door would have to clear?
When all is in place (door and finish floor) you should have no less than 1/4" of clearance.
Dont forget the weatherstripping will hang lower than the door sill.
Edited 9/28/2004 7:52 am ET by maverick
It's hard to predict the thickness of any carpet or mat let alone guestimate the clearance. Easier to use some simple formula; like, set the door a 1-by above the final flooring.
Phill Giles
The Unionville Woodwright
Unionville, Ontario
sills are usually tall enough to be on the subfloor and allow hardwood w plenty of space just measure up 3/4" from bottom of sill to see where top of flooring will be install flashing across the r.o. and a few inches up the jacks, extending 1" into house after door unit installed, form a curb flashing bend up to sill make 45 degree bends where flashing goes up jacks lead flashing easiest to form, no water infiltration to damage hardwood
