I am trying to decide whether it is safe to tile a 2nd floor covered porch in a high wind coastal application. Are there membranes that are reliable and, if so, how do your seal the exposed outer edges of the tilework???
slow down man.
Give people a chance to read what you posted and reply. Might go back and delete your first two posts on this question.
What ... you mean this is NOT a chat room? How gauche!"Put your creed in your deed." Emerson
We are doing a tile deck over living space right now. It is a simple application (no parapet, no penetrations) and the tilesetter is using ProtectoWrap AFM-WM for the membrane. There is a product from Noble called Noble Deck that I would also use. Schluter almost certainly would work also, probably the Ditra material.
Thanks for the info.
In researching Noble deck, it states not to be used in freeze/thaw areas so that concerns me. So far, the Schluter looks like the best alternative. Do you know why you are not using Schluter? How are the exterior edges sealed to prevent rain from breaking down the substructure????
