FHB Logo Facebook LinkedIn Email Pinterest Twitter Instagram Tiktok YouTube Plus Icon Close Icon Navigation Search Icon Navigation Search Icon Arrow Down Icon Video Guide Icon Article Guide Icon Modal Close Icon Guide Search Icon Skip to content
Family room
Intheruff | Posted in Energy, Heating & Insulation on July 22, 2012 07:13am
Added on a new family room has a crawl space only 3 ft from ground . I insulated in between the floor joist and screwed 2″ foam to the bottom of joist . And ran the duck threw the floor joist as well. It sit on a beam so the ground is dirt and I want to close this in can i or should I cover the ground with plastic. Then what should I use for the outer walls concerned about mold and don’t want the wood sitting in the dirt .
  1. DanH | Jul 23, 2012 09:33pm | #1
    No reason not to put plastic on the ground, regardless of what you do with the walls (and provided the crawl does not get water running into it.
  2. rdesigns | Jul 24, 2012 09:42am | #2
    If your 2" foam is reasonably
    If your 2" foam is reasonably tight-fitting at its joints, you will have an excellent vapor barrier to isolate the floor system from any moisture originating from the dirt below. Covering the dirt with plastic sheeting would be extra insurance againt moisture that could affect any framing not covered by foam board.
    The concrete stem walls could be a path for wicking moisture from the surrounding outside ground, depending on local conditions and on how well you direct rainwater away from the foundation. Even then, if the outside of the concrete was thoroughly sealed with tar, there would be very little moisture migrating thru it into the crawl space..
    You need to ventilate the crawl by some method, and your options on that can be explained by your local jurisdiction/building inspector.
Practical and Sustainable Prefab Home
Two boxes make up the plan for this modular house: One has the kitchen and common area, while the other includes two bedrooms and two baths.
  • Convert a Porch to a Mudroom
  • Podcast 599: Trees Moving Buildings, Epic Thermal Bypasses, and Supplemental Dehumidification
  • Podcast 599: Members-only Aftershow — Tools That Changed Residential Construction
  • Remodeling Done Right
BOOKS, DVDs, & MERCH
Shop the Store
  • 2023 Tool Guide
    Buy Now
  • Code Check Complete 3rd Edition
    Buy Now
    Buy Now
  • Pretty Good House
    Buy Now
  • Shop the Store
  • Issue 318 - October 2023
    • Make Mudsills Square and Level
    • Turn Up the Heat With Induction Cooktops
    • The Fine Homebuilding Interview: Lloyd Alter
  • Issue 317 - Aug/Sept 2023
    • Finishing Drywall With Seamless Results
    • A Flat Roof in a Cold Climate
    • Compact Cordless Shop Vacs
  • Issue 316 - July 2023
    • Timber-Framed Solar Canopies
    • Build a Transom Above a Stock Door
    • Understanding Toilet Design and Efficiency
  • Issue 315 - June 2023
    • How to Craft a Copper Roof
    • 5 Lessons from Building in a Cold Climate
    • The Advantages of Cellular PVC Siding
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
