Fastening box newels
cobbleboy | Posted in General Discussion on December 12, 2006 05:45am
Hey all.  Wondering what personel preferences are for fastening box newels to the floor.  Floor is reclaimed heart pine.  Subfloor is 1x diagonal to joists with 5/8 ply on top.  Double 2x10s on stairway opening.  Will be el shaped with two box newels and one return to wall.  Thanks.  Joel
  1. rez | Dec 13, 2006 09:08pm | #1
    Greetings cobble,
    This post, in response to your question, will bump the thread through the 'recent discussion' listing again.
    Perhaps it will catch someone's attention that can help you with advice.
    Cheers
    damn, am I fat!
  2. dovetail97128 | Dec 13, 2006 09:13pm | #2
    Do you have open access to the framing or is the ceiling applied already? Makes a difference in my approach .
    1. cobbleboy | Dec 14, 2006 11:47am | #6
      Yes, I do have access to the framing underneath the floor.  I know that there a a variety of products on the market for this task, but I was wondering what the personal preferences of people were and why.  I guess that i am little chicken [email protected]# at drilling into my new floor that I have spent so miuch time and money into.  Thanks joel
    IMERC | Dec 13, 2006 10:28pm | #3
    4Js post mounting system...
    http://www.coniferproducts.com
    WOW!!! What a Ride!
    1. cobbleboy | Dec 14, 2006 11:54am | #7
      The only thing I saw on the web site was for solid newels.  This will be be for box newels.  Joel
      1. cobbleboy | Dec 14, 2006 12:00pm | #8
        Has any body used this http://www.stairparts.net/box-posts.htm  per chance?  And has anybody used their products?  Thanks joel
        1. Snort | Dec 14, 2006 04:35pm | #9
          Haven't used the EZ Mount (Dino's cousin ya think?), but I've made similar. It's pretty easy.Since you can get to the framing from underneath, the job is way easier. If you can you can notch the post around the double joists (I'm assuming here), you make the newel rock solid, and with no visible fasteners.Timber Loc makes a great lag screw for for this. Oh God said to Abraham, "Kill me a son"
          Abe says, "Man, you must be puttin' me on"
          God say, "No." Abe say, "What?"
          God say, "You can do what you want Abe, but
          The next time you see me comin' you better run"
          Well Abe says, "Where do you want this killin' done?"
          God says, "Out on Highway 61."
        2. dovetail97128 | Dec 14, 2006 07:22pm | #11
          If you are referring to the box newel fastening block , no . But it sure looks like it would work as well as anything I have done.
          I make a block like what you showed and run an "all thread" thru it and the joists below , glue the bottom of the block and tighten the "all thread". The premade block eliminates vertical alignment problems with the joist below. I like it.
          Edited 12/14/2006 11:23 am ET by dovetail97128
        IMERC | Dec 14, 2006 06:06pm | #10
        kinda pick and choose depending on yur finale
  4. Tomrocks21212 | Dec 14, 2006 02:39am | #4
    The last one I did with a hollow boxed newel, I built another box out of 1x that just slipped inside it. The inner box passes through a square hole in the floor and is attached to the framing below.
  5. DougU | Dec 14, 2006 04:07am | #5
    I did a box newel lately that was 8" X 8", located in the basememt on concrete.
    I tapconed a piece of 2 X material that just fit into the newel, PL'd the hell out of it and sliped the newel in place/over it and screwed it down around the perimiter. Screws will be covered by base that get wraped around it.
    One other thing I forgot to mention was that I wedged a 2 X 4 vertical above the newel in order to apply presure,  this insured a tight fit when I screwed it to the pad. Solid as a rock!
    I've used the thing-a-majigs that IMERC showed you in an earlier post and they work fine too.
Hole Saws That Are a Cut Above
The Spyder carbide-tipped hole saws cut quickly with a quick-release arbor that makes it easy to remove the core.
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
  • Podcast 549: Members-only Aftershow—Patios vs. Decks
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
  • Strategies for Venting a Roof Valley
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • 2023 Tool Guide
    Buy Now
  • Pretty Good House
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
