fence building thoughts, question
| Posted in General Discussion on January 13, 2004 10:49am
     As part of a bigger job, I’m building a picket fence. Although I’m being paid on a time & materials basis, I’d like to work up as accurate an estimate I can, and it occurs to me that someone out there must have developed a pretty good system for this. Because of the obvious number of variables involved, I’m not really interested in a boardfoot or linear “price per” formula.  I would like to know if anyone has worked out a way to anticipate man hours on things like setting posts (with concrete, hand mixed, in soil) and cutting pickets (in this case, two straight cuts per board – I’ll do them 3 at a time on a chopsaw). I’ve only built one picket fence before, and if I hadn’t been working for a friend and paid in beer, I would’ve paid more attention to the time it took. I do remember that the “assembly line” approach came in handy, especially in milling and finishing the pickets – we determined that the wood was dry enough to actually stain the rails and posts before installing the pickets (which were group-sanded and stained themselves).  A jig for spacing and height (off the top rail) was essential, too.
      I welcome any similar tips on this subject, but I’d really like to hear some thoughts on estimating time. Anyone?
    Sphere | Jan 13, 2004 04:26pm | #1
    make your best guess...then double it..I have done miles of bobbly wire, electric and welded wire..same holds true.
  2. Mooney | Jan 13, 2004 05:00pm | #2
    I bid an hour per post and 10 ft per hour  not counting the obvious materials. I can beat both times but stuff happens and it can take me longer in rock or bad weather . Thats still on average a truthful time. You can add things like mixers and post hole diggers  but they need to be paid . I can rent a post hole digger that is very nice and digs fast . If Ive got enough holes it pays . Same  for mixer , although I have one.
    Does the chop saw have a fence that you can do repeat cuts ? If its a big fence it changes things . I run a trailer with the materials, generator and chop saw on board with a table saw . Like a half acre yard or bigger . Bigger yards will accept a tractor and post hole digger and some you have to dig by hand for all the rocks .
    Rocks make a big difference in my mental attitude .
    Tim Mooney
    1. davidmeiland | Jan 13, 2004 06:51pm | #3
      My neighbor puts in miles of fencing around the county. He hand digs everything and gets 3-4 posts per hour in. These are heavy log posts in 18-24" holes done with a clamshell and we have plenty of rocks just under the surface.
      I did the same around part of my place. 300 feet+/- and about 35 posts took one long day to dig and set (tamped rock, no 'crete') but we used an auger on a tractor except for about ten posts near the buried phone wire, which I hand dug for added torture. Oh yeah, call for a utility locate if there's anything buried anywhere nearby.
      Any chance you can buy the pickets pre-cut and skip that part?
      1. skids | Jan 13, 2004 10:07pm | #4
        ya i was gonna say buy pre-cut too! my wife did a custom paint job in my daughters bedroom that features a picket fence. she used a picket that she got from a friend for the pattern. picket fences are not square on the top, they go up to a kind of spade from a deck of cards looking type of thing, and i am sure you can but them pre-cut, just not sure where. even if you don't want that pattern, you should be able to get them pre-cut somewhere, and pre-cut should save money.
      2. Mooney | Jan 14, 2004 02:40am | #5
        But  ah ,... I dont tell how long it takes .
        Tim Mooney
