I have a fiberglass tub that has a 2 in crack in the bottom. There are no pieces missing but water can leak through the crack. The house is on a slab so there is no access to the area under the tub. The floor beneath the tub has some give to it. Can the crack be repaired w/o removing the tub? Should some foam or other material be put beneath the tub to support it to prevent it from cracking again? Thanks.
Ford Motor Company slashes prices for some F-150 Lightning models to stimulate demand for electric vehicles (EVs).
tub crack
Our local plumbing store has an employee that is trained to fix fiberglass tubs on site. I have witnessed him perform magic and save the day. However, the general rule of thumb is any crack (not a chip) on the standing portion of the tub cannot be fixed.
It can be fixed, but as the previous post indicates fixing a crack in the standing area is iffy. Best fix in the standing area would be to grind away the gelcoat, put down a layer of glass, then replace the gelcoat, but it will leave a large (8-12" square) rough area. Fixing just the crack, such that the "damage" is limited to a roughly 4x4" area, would be much less likely to hold, if the problem spot is a place where people stand.
I used to think that maybe drilling a small hole and injecting foam would help, but I've thought about that over the years and I doubt that it would do any good. The force from someone standing can be 200-300 psi, which is much more than the foam will support.
