Took up wall to wall carpeting and the tack boards left little holes in the flooring.
Now that I am refinishing how do I get wood putty to look like lite oak?
Help
Help
There's a constant source of clean water for you to use, and all you have to do is collect it.
use yur saw dust (ultra fine) and clear glue...
mix to tooth paste consistency and hand rub it in...
WOW!!! What a Ride!
Edited 8/21/2006 10:32 pm by IMERC
Terrific. Will Elmers glue that dries clear work and will I be able to put Bona Traffic over it when I'm done?
Do you think I will need a sealer on the bare wood before I put the Bona Traffic down?
Cant thank you enough for your help
Look up floor refinishers in your area. They use a clear liquid (name escapes me) specifically for this purpose. The more sawdust you mix with this clear liquid the 'dryer it gets. Refinishers smear it into the cracks and crevices and give the floors as final sanding.
aslong as it's not white glue...
see reinvent's post...
where are you???
I live in Chicago
I will check the store that carries the Bona Traffic maybe they will have something because all I have is white glue that dries clear.
Thanks again
Keep the ideas flowing -It is really great help to newbees like me.
look up a better wood working outfit.. they'll have it...
make yur own.. it'll match better...
Edited 8/21/2006 11:47 pm by IMERC
