To vent a shed roof where the top end meets a wall, have you used the flash called Filter-Vent? If so, give me some tips on installation, beyond what I can see from working with the sample I’ve got.
The attached pic shows it in cross section.
Not much to it. I like to seal under the vent with Quad caluk due to the pressure of wind hitting the wall.
Also flash in the top with a small strip of ice and water shield before siding.
Do not cut air grove bigger than in instructions.
