Finishing off an open beam ceiling – How to insulate?
dkiefer | Posted in General Discussion on May 11, 2011 01:23am
Hello,
I have an open beam ceiling that I would like to cover up with drywall. What type of insulation should I use under the drywall if I don’t have the ability to ventilate the cavities? The beams are 2′ on center spacing and are 5.25″ thick. The roof side of the ceiling has about a 3″ foam board insulation.
Thank you,
David
  1. DanH | May 11, 2011 07:59am | #1
    Well, you can use anything you want UNDER the drywall.  And above the drywall it's not a issue of insulation type so much as it is potentially capturing moisture.  Might be best to not insulate at all and install a few small vents somewhere.
Choosing a Paintbrush
  • The New Old Colonial
