Finishing Pine Floor
| Posted in General Discussion on October 5, 2004 11:55am
Recently installed a wood floor using salvaged Pine boards. During the salvage process (came out of a house from the 1830’s that was never electrified!) the tongue and grooves were pretty badly damaged so I ended up ripping each side and face nailing with repro square cut nails. The boards had been face nailed before – left lots of oxidized old holes. Also planed each board to get as flat as possbile without losing too much thickness. Looks great and looks old, too. But… I do need to finish it and that is the issue at hand.
First, I would like to fill in the old holes (there are alot) before sanding. I saved lots of sawdust and thought about using mixed with wood glue as a filler. I suspect this would be a problem if I was planning to stain because this will not accept stain. But am now considering not staining, just putting some type of protective coat on. After all the trouble to get the “old house” look I can’t imagine using a poly type that will leave a plastic look – possibly an oil finish?
Am open to ideas from those with more experience. Desired result would be the most durable finish (I realize it’s pine and don’t expect miracles here) while still maintaining the character of the old wood.
Thanks in advance for your advice.
  1. JonE | Oct 06, 2004 01:01am | #1
    Fill nail holes with mixture of sawdust and shellac, let dry, finish with satin polyurethane.
    1. Scooter1 | Oct 06, 2004 03:29am | #2
      Epoxy and sawdust works better than shellac.
      Regards,
      Boris
      "Sir, I may be drunk, but you're crazy, and I'll be sober tomorrow" -- WC Fields, "Its a Gift" 1934
Sloping a Deck: Is This Necessary?
Mike Guertin explains which areas of a deck you need to pay attention to in order to deal with drainage.
Get an overview of the process of creating a traditional-style fireplace that burns well and meets current building codes from experienced mason Mike Mehaffey.
  • Podcast 550: PRO TALK With Carpentry Program Instructor Sandy Thistle and Graduate David Abreu
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
  • Podcast 549: Members-only Aftershow—Patios vs. Decks
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
BOOKS, DVDs, & MERCH
Shop the Store
  • Pretty Good House
    Buy Now
    Buy Now
  • 2023 Tool Guide
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
