Fire Rating: Sheetrock and Hardi close?
Seeing the post on weights of sheetrock, the weights of sheetrock and same size panels of Hardiboards are close to the same weights per sheet. It got me thinking about comparing fire ratings.
Would 5/8″ sheetrock and Hardi Serrica Vertical Siding sheets have the same fire ratings?
Thanks,
Bill
I am not familiar with the Hardie product you mention, but I do know that Hardie Plank alone does not get a class A fire rating. It requires an assembly with 5/8 fire rock.
John
I suspect that the problem is that the plank has seams. A hot fire could cause the seams to open up, allowing the heat/flames through.Likely a face nailed assembly would test better than a blind nailed assembly.
http://www.jameshardie.com/homeowner/fire_faq.shtml
http://www.jameshardie.com/homeowner/fire_technical.shtml
Yeah, gypsum wallboard has the advantage of a very high water content, though I'm guessing Hardi is no slouch in that department.
I doubt it.
Gypsum owes it's amazing fire performance to it's unique crystal structure, one that traps two water molecules inside it.
You can see the effect of this if you set a piece of drywall on a stove. You'll actually see a wet spot, as the first water molecule is boiled out of the crystal, at around 250F. Then, much later and at a much higher temperature, you will see steam escape as the second water molecule is cooked free.
Cement, mortar, etc. does not have this trait. I think there is only one water molecule trapped within.
Masonry does have one advantage over gypsum; it seems to retain it's mechanical strength after losing that water molecule ... unlike gypsum, which turns into talcum powder.
