Is there a liquid product to fill small cracks, 1/16″ to 1/8″ wide that could be poured into cracks where movement has occurred. Stopping water from getting in would prevent the freeze/ thaw expansion. I would like to try this prior to re grouting with a superior grout and buy some time. Any ideas.
Thanks,
Steve
Custom's Building Products makes 'pour stone', Laticrete and others makes self-leveling cement, many mfg make a hyd cement. Lots of products, don't know which is best, but that's a factor of several things, such as how easy to work, and not necessarily durability of product.
*Another product is the urethane-based concrete joint sealers. But, if you don't put a "bond-breaker" at the back, the sealant will not flex and will open up again. Most commonly used is a rope of foamed polyethylene which is pushed to the back of the hole.
Is there a liquid product to fill small cracks, 1/16" to 1/8" wide that could be poured into cracks where movement has occurred. Stopping water from getting in would prevent the freeze/ thaw expansion. I would like to try this prior to re grouting with a superior grout and buy some time. Any ideas.
Thanks,
Steve
