Flashing for electrical mast penetration
I have a 2″ rigid pipe mast (through asphalt shingle roof) which has no flashing around it, only asphalt mastic seal. Is there any readily-available split flashing made for retrofits? All the items available locally require installation over the pipe, which cannot be done because of the permanent electrical connections.
Any suggestions appreciated.
Question was asked about a week ago. There is a 2-piece retrofit boot available, but you'll probably have to go to an electrical supply house vs a big box store to find it.
No electrons were harmed in the making of this post.
Look for the retrofit boot on the plumbing isle of the local big box hardware. Pretty common there.
