Floating Floor
| Posted in Construction Techniques on September 24, 2003 03:53am
Is it necessary to install a plywood subfloor for a wilsonart type floating floor over a concrete slab? I was led to believe a vapor barrior and padding was all that was necessary under pergo/wilsonart floors. Also has anyone used the wilsonart tap and lock floors. I havent done a wilsonart panel floor in years and recently found out they don’t make the glued plank system anymore. Now it just snaps together? Don’t know if I care for that.
                         Tim
  1. Gabe | Sep 24, 2003 04:08am | #1
    No but it's necessary to install a plywood layer over a wilsonart floating floor that's layed over concrete.
    Sorry couldn't resist. I rate wilsonart and pergo right up there with vinyl siding.
    What you do need is
    1. a dry concrete floor that doesn't have moisture problems because the VB between the two will not help you.
    2. a level concrete floor that doesn't have a kinds of hills and hollows to contend with otherwise your joints will fail.
    Gabe
    1. andybuildz | Sep 24, 2003 03:07pm | #2
      Whats this world coming too? Like Frank Zappa (rest his soul) said many moons ago....Plastic People.
      He was way ahead of his time.
      Be Zapped
                      andyTrue compassion arises out of the plane of consciousness where I "am" you.
  2. mikeys | Sep 24, 2003 04:02pm | #3
    I'm not a fan of laminate flooring but did install a snap together floor last year. I don't know the brand but the substrate edges were coated with wax to seal between pieces. It sure was easy to install.
    Smile. It could be worse. You could be me working for you.
Choosing a Paintbrush
  • The New Old Colonial
