Brick home w/ 30 lb.felt over 4-inch studs,insulation,then sheetrock.Demo crew tears out bottom 4-feet of sheetrock and insulation but also takes felt w/ it.What do I put/coat on the inside of the bricks to create a vapor barrier.Remember in hot,steamy South Louisiana we want to keep the humidity outside, not inside.
Learn about balloon-framing construction techniques, including stud patterns and efficient assembly methods with minimal manpower and scaffolding.
Spray polyurethene foam
Thank you!!!!
