We just put in a red oak select 2 1/4 x 3/4 hardwood floor. How long would you leave it down before sanding and finishing it? Also, which would you use, the water base or oil base finish. We are leaving it natural so we are not using a stain.
We think we would like to use the water base because we have heard the oil yellows after time, but have also heard that the water base is not as durable as the oil.
Please let me know your thoughts on this matter and anything else you think could help!
thanks,
Lisa
Greetings tncoins, Welcome to Breaktime.
This post, in response to your question, will bump the thread through the 'recent discussion' listing again.
Perhaps it will catch someones attention that can help you with advice.
Cheers
"Live Free,
not Die"
The post has also been made elsewhere and answered there.
IanDG
Don'tcha just hate when that happens.
I'm thinking when they don't get a quick reply they'll repost in another folder thinking a better chance of getting a response.
Messes with my technique.
but bestbe thorough
be no newbie left behind"Live Free, not Die"
personally I prefere oil based finishes for floors. Much more durable.
If you can get the "new" moisture cure finish with acceptable VOC reg's thats the route I'd go. Dries fast and is incredably durable....best to do on humid or rainy days believe it or not.
Far as I'm concerened durabilty is what should be the # 1 concern on a floor.
If you do go with a moisture cure finish be sure you use someone thats experianced doing it. BE sure you use a gloss coat first then a satin if you want a softer look.
It comes "non yellowing" but costs a whole lot more,,,,but worth it IMO.
BE well
a...
Used to be Andy, but not any longer.
The BonaKemi commercial brand 'Traffic' is as good, if not better, than any oil-base -- also it doesn't yellow, doesn't smell and you can apply two coats in a day.
IanDG
Ian
Yeh....I've heard that just never tried it...I do think however that the "moisture cure" finish was the best I ever used.
PS...when I click on your name and that door comes up.....what is that?
BE a limey
a...The secret of Zen in two words is, "Not always so"!
Andy,
Where's your sense of adventure??
Open the door, man, open the door!!
The waterbases have been steadily improving over the last 10 years -- largely driven by the constantly tightening VOCC regs which will eventually see the end of anything else.
IanDG
Edited 2/12/2005 9:56 pm ET by IanDG
