Floor joist size
| Posted in Construction Techniques on May 1, 2005 04:22am
I need to build a closet in an attic.  I suspect it will be crammed full of junk, more than just holiday decorations.  The clear span is under 8 ft … in fact an 8 ft 2x will overhang about an inch on each end.
What size 2x do I need?  Will a 2×6 be ok?
I’m sorry, I thought you wanted it done the right way.
  1. Gumshoe | May 01, 2005 05:09pm | #1
    Not entirely sure without a sketch, or more specifics, but heres a link that might help.
    1. FastEddie1 | May 01, 2005 06:29pm | #2
      Thanks.  That shows 2x6 @ 16" will span 9'-9" so I'm good to go.
  • Fine Homebuilding's Author Guidelines
