I have a ranch that was built in 1956 with radiant heat in the ceiling and I would like to move it in to the floor and was considering using Gypcrete. the original set of prints called for 3×12 floor joists at a span of 22-1/2 feet over the largest portion of the house. the rest of the house has 2×12 floor joists with the span of 16 feet. Will this take the weight of the Gypcrete? I can’t do an under floor installation since the basement has a finished plaster ceiling? Gypcrete seems like a nice solution since I have some uneven floors. Thought about “warm board” but appears to be very expensive. Any suggestions are welcome.
-Ed
There's a constant source of clean water for you to use, and all you have to do is collect it.
I have a ranch that was built in 1956 with radiant heat in the ceiling and I would like to move it in to the floor and was considering using Gypcrete. the original set of prints called for 3x12 floor joists at a span of 22-1/2 feet over the largest portion of the house. the rest of the house has 2x12 floor joists with the span of 16 feet. Will this take the weight of the Gypcrete? I can't do an under floor installation since the basement has a finished plaster ceiling? Gypcrete seems like a nice solution since I have some uneven floors. Thought about "warm board" but appears to be very expensive. Any suggestions are welcome.
-Ed
