FHB Logo Facebook LinkedIn Email Pinterest Twitter Instagram Tiktok YouTube Plus Icon Close Icon Navigation Search Icon Navigation Search Icon Arrow Down Icon Video Guide Icon Article Guide Icon Modal Close Icon Guide Search Icon Skip to content
flooring for a converted screened porch
user-149771 | Posted in General Discussion on January 30, 2005 05:05am
I built a 16×16 screened porch with cathedral ceiling on my house with the idea of eventually installing windows and insulating it for year round use. I have access from below, so I can insulate under the floor and then close up below with PT plywood or t&g siding. I have 1×4 mahogany decking running across my p.t. joists, and I’m looking for ideas about finishing off the floor without having to remove this as the exterior walls are built on it. I suppose I could lay t&g flooring over the mahogany and install thresholds at the doors. Or add a layer of 3/4 plywood and tile it??? Hmmmmm. Guidance requested.
  1. DanH | Jan 30, 2005 08:43am | #1
    Just indoor/outdoor carpet works well. Blocks air flow and warms the floor. Can be layed without glue -- just install trim around the edges to hold the edges down.
    Below, install fiberglass batts, then garden fabric, then hardware cloth. Isn't great insulation, but is "drip dry".
    For the windows, use Monray WindowWalls.
Fastening Outside Corner Bead
On an outside corner formed by a double layer of drywall, the corner bead can be fastened without nails or screws.
  • Issue #320 – Dec. 2023/Jan. 2024
  • Podcast 607: Wood Foundations for Winter Builds, Adding Headroom, and Aeroseal for Leaky Ducts
  • Podcast 607: Members-only Aftershow—Holiday Gifts for Home-Building Enthusiasts
  • Fine Homebuilding Issue #320 Online Highlights
BOOKS, DVDs, & MERCH
Shop the Store
  • Code Check Complete 3rd Edition
    Buy Now
  • Pretty Good House
    Buy Now
  • 2024 Tool Guide
    Buy Now
  • 2023 Fine Homebuilding Archive
    Buy Now
  • Shop the Store
  • Issue 320 - Dec 2023/Jan 2024
    • How to Reuse Salvaged Wood
    • Chainsaw Retrofit and Energy Performance
    • Maximize HVAC Efficiency
  • Issue 319 - November 2023
    • Nearly Net-Zero ADU
    • An Easy Approach to Coffered Ceilings
    • Understanding Types of Roof Vents
  • Issue 318 - October 2023
    • Make Mudsills Square and Level
    • Turn Up the Heat With Induction Cooktops
    • The Fine Homebuilding Interview: Lloyd Alter
  • Issue 317 - Aug/Sept 2023
    • Finishing Drywall With Seamless Results
    • A Flat Roof in a Cold Climate
    • Compact Cordless Shop Vacs
  • Issue 316 - July 2023
    • Timber-Framed Solar Canopies
    • Build a Transom Above a Stock Door
    • Understanding Toilet Design and Efficiency
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
Start your subscription today and save up to set_percent%
