Flooring material question
CardiacPaul | Posted in General Discussion on April 14, 2007 10:22am
Time to replace our kitchen, dinette, rear hall & powder room flooring, I have armstrong vinyl for the last 18 years & it has held up very well, but its time.
The wife & I like wood but both agree with our life style & the wear & tear factor and crushed limestone driveway, its just out.  Vinyl is out do to we just can not find anything to our liking  & like I said,   “18 Years”.  Laminates, No way,  Not to offend anyone but we just do not like the look or hollow feel , durabilty seems good, however I’ve seen a lot of open joints with the stuff.  Ceramic may be in although pretty labor intensive & cold.  Heat mat sounds good although cost wise, about 450 sq. ft. this will add up.  I have 5/8 OSB sub floor & 5/8 AC with the current vinyl over that now, this is glued & nailed to 2x10s 16″oc on 13.5′ span.  All is very solid.
We were shopping & found  Congoleum’s ” Dura Ceramic”                 http://www.congoleum.com/res-products.php?product_line=duraceramic
Have any of you used this product & have any thoughts.
Thanks for any input you may have.
Paul.
Edited 4/14/2007 8:54 pm ET by CardiacPaul
  1. rez | Apr 17, 2007 08:00pm | #1
    Greetings CardiacPaul,
    This post, in response to your question, will bump the thread through the 'recent discussion' listing again which will increase it's viewing.
    Perhaps it will catch someone's attention that can help you with advice.
    Cheers
    Parolee # 53804
  2. billybatts | Apr 18, 2007 09:23am | #2
    I have seen it installed over a substrate that the people thought was unsuitable for ceramic...anyway...i thought it was ceramic until i asked them..."is that ceramic or porcelain" and they said "actually it's dura-ceramic" It looks amazing and there was no cracking in the grout lines although i understand you can have the option of not grouting it.
    Probaly not the labour cost also that ceramic has.
    go for it!
