I have about 16 flush pulls to install on pocket doors. I have a small router/laminate trimmer. Any ideas on how to build a jig for such a project. Or any recommendations for books, articles that cover the subject well. Thanks, Chris
Screw the pull to the door edge, inside out. Trace/ mark edge with pencil.
Do the same thing on the face off a peice of 8" x 12" plywood. Cut out the plywood hole.
Clamp 2 peices of 1x to the door flush with its edge. Place ply over door edge so it aligns with tracing on door edge. Nail or screw ply to 1x.
I am sure you can figure out the rest.
Frankie
There he goes—one of God's own prototypes—a high powered mutant of some kind never even considered for mass production. Too weird to live and too rare to die.
—Hunter S. Thompson
from Fear And Loathing In Las Vegas
I use a guide bushing. Here is a pic of one. Sold usually in sets of 6 to 8 sizes, they accommodate bits of various diameters and provide specific offsets.
Lets say I want to rout a mortise in the door edge that's 1" wide by 2-1/4" high. If I use a 1/4" dia. bit and a bushing with outside dia. of 3/8", the bushing guides the bit at an offset distance of 1/16".
So, overall I need a template hole that is 1/16" all around larger than the size of mortise I want to cut.
I like to use 12mm baltic birch plywood for templates like this. I would rip a small strip at precisely 1-1/8" width, cut it in half, then egdeglue them with larger flanking pieces to make a template that ends up with a rectangular hole in it of size 1-1/8" x 2-3/8". With some edgeguides screwed to the backside, I can clamp it to the door and rout my mortises.
Make a template in 1/2" MDF that is the exact outline you want for the hole. Then fit your router with a template bit (a straight bit with a bearing the same size as the bit mounted at the top). Clamp the template onto the drawer/door front, align the hole, set the bit depth and rout away.
Ridge Carbide, MLCS and other bit suppliers will carry these. Attachment shows what the bit looks like.
Every thing that was said plus, the smaller the bit the less radius you'll have to chisel out on the corners. You can buy a "corner cutter" but I don't think they're worth it.
Thanks to all for your help on this. Your input is a great help to me. Chris
