I am renovating a 1923 Sears cottage in upstate NY. It has no insulation in the walls. Can a foam insulation be installed between the studs without stripping off the wall covering, and if so, are there different types of products.
Go here. http://www.fomofoam.com/index.htm
Not cheap but good stuff and easy to use. See this one too for some more options.
http://www.easy2.com/cm/easy/diy_ht_index.asp?page_id=35693880
Check out blown in fiberglass. Small holes are drilled high and low, insulation is blown in, and the holes are then either patched or covered with a "push" cap.
Better to use cellulous than FG. Has better R per inch and is made from recycled matterial. See http://www.regalind.com/cellulosevsfiberglass.htm
