How can I best insulate the 5ft high crawlspace at my cabin. The walls are rubble….mortar and stone of every shape and size…..very rough. The floor is dirt and also very uneven. The floor joists are different size logs and spacing. The area is damp and I do not want to construct stud wall etc since I use the space only for storage. Is there a product that a do- it- yourselfer can spray on the walls?
Mauri
Edited 10/28/2004 4:04 pm ET by camper
Greetings Mauri
If you scroll down in the lower left corner of your screen there is a search function that will take you to previous threads dealing with whatever you type in the search bar.
I typed in spray foam and got a good supply of data on the subject.
Cheers
