Foam & Vapor Barriers
| Posted in General Discussion on August 7, 2000 08:07am
Greetings from Minnesota:
My wife and I are in the process of remodeling an alder home. Basically we have gutted the interior. My question is: We are planning to insulate the walls (2×4) with R13 fiberglass bats and then place 3/4 inch foil face foam over that. Do we need to install a separate vapor barrier or will the foam be sufficient? Of course we would tape the seams. We were also considering using the ploy wrapped fiberglass bats. Thanks in advance.
  1. Patrick_Pellowski | Aug 07, 2000 08:07am | #1
    My wife and I are in the process of remodeling an alder home. Basically we have gutted the interior. My question is: We are planning to insulate the walls (2x4) with R13 fiberglass bats and then place 3/4 inch foil face foam over that. Do we need to install a separate vapor barrier or will the foam be sufficient? Of course we would tape the seams. We were also considering using the ploy wrapped fiberglass bats. Thanks in advance.
A Practical Perfect Wall
  • The New Old Colonial
