For Modified Roof, use 43lb base sheet?
BilljustBill | Posted in Construction Techniques on July 28, 2008 06:59am
A new grandulated modified roof is going over my open patio.  Currently it has a 14yr old, non-leaking, 4-layer mopped roofing with a roll-on Aluminum sealer.
The original decking is 1/2″ ply and the new modified roof is being bid with a 43lb base sheet.  Is that thick enough?
The patio roof is a shallow 1-1/2-12′ slope, on the 16′ width and is 44′ long.  Tear off, tie-in, and hot mop bond between the modified granular layer and the base sheet is bid at $3,400.   Is that price Good or bad?
  Thanks for your help,
   Bill
  1. rez | Aug 01, 2008 07:06pm | #1
    bump
  2. Piffin | Aug 01, 2008 10:29pm | #2
    darn good price for that.
    43# base is typical for all BUR
    1. BilljustBill | Aug 01, 2008 10:38pm | #3
      Thanks for the insight, Piffin.
      What roof (and brand) would be the next level of upgrade to the Mod. B. that's hot mopped on?
        Bill
      1. Piffin | Aug 01, 2008 11:11pm | #4
        I don't know if you will do better in a hot applied for a small job like that. The quality will show ( or not) in the tie-in and flashings
