what is the best way to remove the edge band on a counter top to replace formica. would a heat gun work would like to relaminate damaged area
Just borrow your wife's clothes iron. That wiil put the
heat where you need it only, works pretty fast too!
Another option in a well ventalated area is a syringe and laquer thinner. With the use of a small putty knife this will do the trick. It is fast as well.
