Fourescent Light Install
anthonygualtieri | Posted in General Discussion on September 6, 2014 10:04am
Can flourescent lights ( they have stand-offs on the mounting surface) be flush mounted to a sheetrock ceiling?
  1. gfretwell | Sep 06, 2014 11:07am | #1
    I can't imagine why not. The electronic ballasts used in new ones run pretty cool.
  2. oops | Sep 06, 2014 11:35am | #2
    Mounting Fluor. Fixtures
    When you say flush, do you mean the top of the fixture hard against to the ceiling or  the fixture flush with the ceiling as in a
    recessed installtion?
    If there are stand offs,  there is probable a reason for them.  If the ladder, insalling a surface mount fixture as a recessed could be tricky.
    1. anthonygualtieri | Sep 06, 2014 03:30pm | #3
      flourecents
      They are against the ceiling, not recessed.
      1. DylanMitchell | Sep 20, 2014 02:22am | #6
        Re:
        I think recessed ones would look better against the ceiling you have.
  3. DanH | Sep 06, 2014 05:25pm | #4
    It's certainly done all the time -- just screw through the housings and into the ceiling.  To the degree that there's a "stand-off" it's basically to provide clearance for the screws that secure the ballast, etc, since they project through the back 1/4" or so.
  4. anthonygualtieri | Sep 06, 2014 10:23pm | #5
    Thank you for the information.
Tall Deck on a Sloped Lot
When deck posts exceed what the prescriptive code tables allow, it's time to consult a structural engineer for post sizing and possible bracing.
  • Sharp-Blade Solution
