While the actual building is a while off, I figured that I should get some things straight in the meantime.
I’ll be building at least one shed right up against the side of my new trailer. I have large pieces of safety glass that I want to stand on end to make up a large portion of the wall that faces the street. These pieces of glass are exactly 2 feet wide and 67 and a half inches tall. Because of this, I can’t put the studs on 2 foot centers.
Should I just use 4×4’s for the studs there, and just put them on the wider centers to fit the glass in, or should I do the framing in some other way ?
Since this will be a ‘shed’, and will be 120 sq ft or less, it doesn’t require a permit. But I’d bet there is some sort of code that applies anyway, and I don’t want to be caught with my pants down on this one.
Luka,
Make up a 4"x6" header the full length of the glazed wall. Then rabbet a 3/4" by thickness of the glass plus an eigth rabbet into clear 2x4's, one for either end of the wall and 2 between each pair of windows. Frame the wall leaving 24 1/8" between shoulders of the rabbets. The height of the opening should allow for a glazing block (used to take up irregularities in the wooden sill,) to be placed beneath the glass. This is especially important if yours are multi-paned assemblies as an irregular sill will cause seal failure in the glass assembly. 1x stock can be screwed in place between tops of the studs to provide a glazing seat at the top.
Once the windows are sealed in place, a metal or wooden cap can be caulked in place over the rabbets to provide protection for the exposed part of the studs.
*Thank you, Lance. These are simply sheets of greenish, wavey, safety glass.I still haven't decided whether to make them double-pane, or to just go for the most daylight, single-pane them, and make up some sort of frames with plastic for storm windows for the winter.
I'll be building at least one shed right up against the side of my new trailer. I have large pieces of safety glass that I want to stand on end to make up a large portion of the wall that faces the street. These pieces of glass are exactly 2 feet wide and 67 and a half inches tall. Because of this, I can't put the studs on 2 foot centers.
Should I just use 4x4's for the studs there, and just put them on the wider centers to fit the glass in, or should I do the framing in some other way ?
Since this will be a 'shed', and will be 120 sq ft or less, it doesn't require a permit. But I'd bet there is some sort of code that applies anyway, and I don't want to be caught with my pants down on this one.
