Framing nails for a workshop assembly bench
dw833 | Posted in General Discussion on March 19, 2025 09:15am
I’ve searched online and can’t find a direct answer for this question.
Thought I would post here instead of FWW.
Building a workshop assembly table out of 2x4s.  A basic construction using 2×4 as a frame for the rails and legs.  Will have wheels for mobility and a plywood top.
If I use a framing nailer with 3″ nails, will that provide a stable frame.
Should I use screws or dowels instead.
  1. calvin | Mar 19, 2025 07:59pm | #1
    Personally , I’d use screws. (Not drywall screws)
    Some connections might require bolt,nut, and washers.
    Wheels? At least 2 that swivel and consider locking as well.
    unclemike42 | Mar 20, 2025 05:41am | #2
    If framing nails will hold a code-compliant frame in high winds, and high snow loads, it can be a good solution for your workbench.
    Just like the the framing, the design is important. Consider a diagonal support on the back and sides. (2x4s and/or plywood)
  3. damon780 | Mar 26, 2025 07:13am | #3
    Great discussion on framing nails! For a workshop assembly bench, would you recommend ring shank nails for added holding power, or are standard framing nails sufficient? I’ve been considering building a sturdy bench myself and want to make sure it holds up well over time. Also, while researching, I came across some interesting Popeyes Big Box meal deals—perfect for a break after a long build.
    1. calvin | Mar 26, 2025 09:10am | #4
      Are you kidding me.
      Came here because your search for a work bench fastener produced a chicken ad and just because you have a big heart, you thought you’d help out with a “link” that isn’t linked?
      Oh man, you quack me up.
        unclemike42 | Mar 27, 2025 07:07am | #5
        He might have been chicken. This is turning into a fowl discussion
  4. rajpotleo44 | Apr 06, 2025 05:18am | #6
    3" framing nails will hold, but for a sturdy workshop bench that can handle movement and weight, screws are a better choice—they offer stronger, longer-lasting joints and are easier to adjust or remove if needed. You can use nails for speed, but follow up with screws for reinforcement. Dowels aren't necessary unless you're aiming for fine woodworking precision.
  5. TomD2025 | Apr 15, 2025 10:31am | #7
    If beauty isn’t a concern, then yeah, 16ds will work just fine. Know that they’ll probably split the wood if you use KD 2xs though, since a lot of the joints are at the ends of the boards.
    We build quickie work benches/assembly tables onsite when necessary using a full sheet of 1/2” cdx and 2x4s, using 3” zinc coated screws (drywall-type shape but long) and they’re plenty strong enough. We build the 2x4 frame about 1-1/2” to 2” narrower all around than the sheet, so the ply edge overhang gives us something to clamp to. Screws work great and allow for easy disassembly. For this reason I’d recommend them over nails.
    A lower 2x4 rim for leg support doubles as a spot for an additional plywood shelf for tools and materials.
