framing spans
| Posted in General Discussion on February 2, 2001 01:55am
i am planning to build a trellis out of treated yellow pine. the structure will be supported on one side by the house. Out from the house, I will have two – 6×6 posts which will be spaced 15′ apart. Running parallel with the house i will have 2 – 2×8’s (on each side of the post) to support 2×6’s running perpendicular to the house.
Will the 2 – 2×8’s (15′ run) support 2×6’s on top and maybe even 2×4’s on top of the 2×6’s? thanks for your help.
  1. diddidit_ | Feb 01, 2001 07:14pm | #1
    Wait, wait, I wanna do it this time!
    "You need to ask an engineer."
    And not me. Or Merrette.
    4:04 am????? Jeeeez.
    did
    1. Mercer | Feb 01, 2001 07:16pm | #2
      *How long are the 2x6 going to be? What is ther spacing? I don't see a problem.
      1. Pro-Dek | Feb 02, 2001 12:08am | #3
        *Sounds "OK" Charlie. I'd use 2-18'-2x8's with a double through bolt at each end. this leaves a 12 1/2" overhang from each post.We space from 16" to 24" on the 2x6's. We normally use 3x8 and 3x6 tk cedar when building these arbors. Be carefull what you plant on this thing.Wisteria can take the siding off your house if you don't keep on top of it.You did say this was fastened to your house. Good Luck, Bob
        1. doug_hubbard | Feb 02, 2001 12:35am | #4
          *that will do just fine charlie, except pay attention to the weight of whatever you let grow on it, and what about that connection to the house? Make sure it stands up. Span of the 2x6 's ? Don't have a chart in front of me but about twelve feet is all I'd go...
          1. calvin_ | Feb 02, 2001 01:55pm | #5
            *You bet on the wisteria. And give some thought on tieing to the house. I think I would add some posts and let it stand by itself. Best of luck.
  2. charleyhipple | Feb 02, 2001 01:55pm | #6
    i am planning to build a trellis out of treated yellow pine. the structure will be supported on one side by the house. Out from the house, I will have two - 6x6 posts which will be spaced 15' apart. Running parallel with the house i will have 2 - 2x8's (on each side of the post) to support 2x6's running perpendicular to the house.
    Will the 2 - 2x8's (15' run) support 2x6's on top and maybe even 2x4's on top of the 2x6's? thanks for your help.
New House, Old Shell
A full gut remodel brought new life to an 1821 home that had undergone several misguided renovations.
  • Podcast 569: Bath Fan Installs, Sunroom Trim, and Basement Control Layers
  • Podcast 569: Members-only Aftershow — Rob Yagid’s Addition
  • Fine Homebuilding – July 2023, Issue #316
  • Fine Homebuilding Issue #316 Online Highlights
BOOKS, DVDs, & MERCH
Shop the Store
  • Pretty Good House
    Buy Now
    Buy Now
    Buy Now
  • 2023 Tool Guide
    Buy Now
  • Shop the Store
  • Issue 316 - July
    • Timber-Framed Solar Canopies
    • Build a Transom Above a Stock Door
    • Understanding Toilet Design and Efficiency
  • Issue 315 - June 2023
    • How to Craft a Copper Roof
    • 5 Lessons from Building in a Cold Climate
    • The Advantages of Cellular PVC Siding
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
