frigidaire oven install
mkbug | Posted in General Discussion on December 6, 2004 08:48am
Can you believe the gas inlet is on the bottom? How am I supposed to slide the darn thing in to the cabinet?
My plan is to install a street ell and then to flex gas line to gas valve. Then place two 1x4s on the cabinet bottom to raise it the height of the ell to slide it on. I hope I have the clearance. Lots of double checking with the measuring.
Has anyone else experienced this install problem before and did something different?
Martin
    Sphere | Dec 06, 2004 09:03pm | #1
    no adjustable feet?
    Yup, block it to counter height, and ell it
    why are you hooking it up and not the gas supplier? That's how we do it..getting a test?
    anyway, I have done what you describe, and it will work, but the officials might want a look see at the install b4 gas is turned on.
    1. mkbug | Dec 06, 2004 10:43pm | #2
      It's a replacement. Pull out the old and put in the new.Heads I win, tails you lose.
        Sphere | Dec 07, 2004 12:19am | #3
        well, i'd still want to consult higer ups to make sure it's done proper..do what you need and pray for the best ..don't blame me if the house blows up.Call a gas guy.
Two Ways to Test Windows
  • The New Old Colonial
