Frosting glass
| Posted in General Discussion on November 17, 2001 03:28am
I want to frost the lites on a pocket door that sections off a toilet area. I want to see light but not the person using the john. Any ideas? I found a spray on glass frosting that actually looks great but you can scrape it off which I’m not keen on. Does anyone know of any chemical etchers? I realize grit blasting is an option but I’d rather do it at home and not take the door somewhere. Thanks in advance.
Charlie
  1. Joseph_Calvetti | Nov 15, 2001 09:55pm | #1
    A stained glass supplier will likely have a product called "Armour Etch" which is a gel solution of HF. It leaves a finer frost than sand blasting.
    1. CaseyR_ | Nov 15, 2001 10:10pm | #2
      *The following might give you ideas:http://www.diynet.com/DIY/article/0,2058,1513,FF.htmlhttp://familycrafts.about.com/cs/glassetching/
      1. Robert_Macaione | Nov 15, 2001 10:49pm | #3
        *Chaz,I've used the HF paste many times, but in small areas and fine details. For big frost sections, I blast...Comes out nice and even.
        1. Phill_Giles | Nov 16, 2001 02:54am | #4
          *We just use a piece of wet or dry sandpaper.
          1. David_Thomas | Nov 16, 2001 03:48am | #5
            *If you use any HF, read and follow ALL safety instructions. It is really nasty stuff. Although the paste for etching glass at home is pretty low concentration, it is still HF which can penetrate your tissue and react with your bones. After a major exposure, you end up with a boneless (and very dead) victim.Had a coworker who sandblasted to etch glass for a while. Made multiple templates of rubber mat to protect the areas not being blasted. Kind of like a hikers topo map, the areas to be the deepest where exposed in all templates. The shallowest areas in just the last few. Apparently naked women were the hardest to do because the nipples on the breasts projected so far into the glass that he would sometimes cut through to the other side and have start all over again.
          2. Novy_7 | Nov 16, 2001 04:09am | #6
            *Don't Laugh, A mixture of beer and epsom salts works very well. Let the beer dry and the salts chrystalize. Once the salts are set preserve with a clear coat.
          3. Rein_Taul | Nov 16, 2001 05:01am | #7
            *I never laugh when a beer goes unconsumed...
          4. splintergroupie_ | Nov 16, 2001 07:03am | #8
            *Chaz, you could also look into glue-chipping, which is a pretty simple process of pouring hot hide glue on the glass (make a tape dam around the edges) and letting it dry and cool. The glue both adheres to the glass and shrinks, giving you a frosted pattern as well, but more like ice crystals.
          5. Thaddeus_Raven | Nov 17, 2001 01:17am | #9
            *I've been partial to the texture of glue chip glass. That's the technique used a century ago on saloon windows and barber shop doors. There's good info on http://www.kerseyglass.com
          6. Ryan_C | Nov 17, 2001 03:28am | #10
            *Often designs or letters are "etched" in glass with vinyl stick on letters. The clear frosted vinyl applied to glass really looks like the real thing. Any sign shop should have it.
  2. Chaz_Smart | Nov 17, 2001 03:28am | #11
    I want to frost the lites on a pocket door that sections off a toilet area. I want to see light but not the person using the john. Any ideas? I found a spray on glass frosting that actually looks great but you can scrape it off which I'm not keen on. Does anyone know of any chemical etchers? I realize grit blasting is an option but I'd rather do it at home and not take the door somewhere. Thanks in advance.
    Charlie
Drafting the 2027 IRC
  • The New Old Colonial
