I’m rebuilding a wet wall for a half bath so I can hide the sink drain completely inside the wall with 2×6 construction. The original drain line has a fairly long stub coming off the sanitary tee which just stuck out into the room (ugly). 1920s house with galvanized drains and vents. The stub is threaded into the tee. I need to remove it and replace with a shorter piece. Was this most likely just threaded and tightened or was something else done to make a tight joint. I’ve tried unscrewing it but it won’t budge. I’m being extra cautious so I don’t end up with a disaster that requires more work. Last night I soaked the joint with WD40 and will try again. Does anyone having any pointers as to how I can break this joint free? Thanks.Ga
I would try heating it with a torch and using a very large wrench. Good luck!
Al Mollitor, Sharon MA
its pretty unlikely that you will break the pipe in the wall, thats tough stuff.
heat and big pipe wrench
if you do break the tee, its not a disaster, cut the pipe back a few inches and use an abs or pvc with rubber hubless joints
in fact might be easier to do that anyway and dont bother trying to undo the nipple
Thanks for the advice. I considered your suggestion of cutting back the pipe and inserting a new PVC tee with the rubber couplers. What is the best way to cut this stuff as I have never worked with it before. Thanks again.
Sawzall will get it.
Try tighting the nipple a tweak - fuzz first. That'll generally break the seal / crud loose.
Use the banded repair type hubless connectors. Much stronger and less deflection.
Thanks for the help folks.
sawzall with ametal blade
You could cut it with an angle grinder or a sawzall. If you have one but not the other, use watcha got. I have both, and generally start with the angle grinder because it cuts a wider kerf. If there are parts it can't reach, I finish the cut with the sawzall. Its blade slips easily into the grinder's cut. In confined spaces like attics and crawls, the little grinder is often a lot easier to use. I haven't done the math, but my guess is that the grinder cuts more square inches of cross section per dollar than the sawzall.
-- J.S.
Very likely it's threaded -- mine are. Instead of WD-40, there's a much better product called SiliKroil, from Kano laboratories in Nashville, TN. If anything can release the threads, that will.
But this being galv. drain, be prepared for it to crush and crumble when you put the wrench on it. It can look OK from the outside, but be rusted paper thin on the inside. Strange things can happen given 80 years, I had a section of vent that looked like new inside and out for about 340 degrees, but a segment of about 20 degrees was rusted through from the inside for a distance of a couple feet.
-- J.S.
