Gaps in drywall
jyang949 | Posted in General Discussion on July 21, 2008 04:02am
I bought a precut (24″ by 24″) piece of drywall, but discovered that it is actually 23.5″ by 23.5″.
So, there is a gap of 1/4 inch on two sides of the patch. Do I need to fill in the gap, and with what?
For future reference, is drywall always a little smaller than its stated dimensions?
Thanks,
Janet
  1. ponytl | Jul 21, 2008 04:11am | #1
    funny... i saw those 2x2 drywall stacks today at blowes... $4.99 thinking... at that price i have 20k in the back of my dumptruck as we speak...
    no if they had it marked 24x24" then i'd return it and demand a the 24x24" one...  best i can tell they screwed you out of 12sq inches of drywall...  it just ain't right... pretty soon they'll put 120 oz in a gallon  don't let em get away with it
    p
    JonBlakemore | Jul 21, 2008 04:17am | #2
    Just tape it and go. A lot of the existing joints in your house are probably >1/4".
    Most drywall is the stated size, but your "convenience" piece was probably an anomaly.
    Jon Blakemore
  3. DonCanDo | Jul 21, 2008 04:18am | #3
    I think the drywall panel you bought was probably meant for a drop ceiling.  It needs to be a little smaller to allow room for the grid.
    When I patch drywall, I cut the size I need from a whole sheet so I never need to worry about buying the right size.
    Anyway, 1/4" gap is no big deal.  Fill it with a setting compound (setting compounds don't shrink as they cure) like Durabond.  I don't think Durabond comes in small bags, so If you're only going to need a small amount, you can also use plaster of paris (you'll need to work fast) or Durhams Water Putty.  After it's dry, tape and spackle as usual.
    For the next time, cut (or buy) your patch first, hold it up the section of wall that needs repair, trace it and then make your cut.  Perfect fit every time.
    1. jyang949 | Jul 21, 2008 04:39am | #4
      There were two stands of these pieces and they all fit the display exactly, so for some reason they were supposed to be slightly small. I think Don is right about these being specifically for an application requiring some ease. I was tempted to take it back but didn't want to buy a whole sheet and cut it myself. Thanks for the advice.Janet
      1. [email protected] | Jul 21, 2008 07:38am | #5
        I think it is almost always best to have the patch piece in hand before cutting the existing wall.
  4. FNbenthayer | Jul 21, 2008 12:33pm | #6
    The gap is no big deal, just fill it flush before taping. If you are in a hurry, Home depot carries EZ Sand 5 minute mud (5"x 9" box on a shelf).
    Mix it thick (cold peanut butter), fill, strike it flush, wait 20 minutes, and follow with green top and paper tape.
    The awful thing is that beauty is mysterious as well as terrible. God and the devil are fighting there, and the battlefield is the heart of man.
    - Fyodor Dostoyevski
    1. jyang949 | Jul 22, 2008 01:43am | #9
      What is green top?
      1. MSLiechty | Jul 22, 2008 02:07am | #10
        I'm going to guess toping. or TNT. the box it comes in has a green dot on it as opposed to all purpose with a red dot on the box.ML
      2. BUIC | Jul 22, 2008 02:26am | #11
         I believe he was referring to standard joint compound.
          It comes in a 5 gallon bucket with a green lid on it...buic
      3. FNbenthayer | Jul 22, 2008 02:29am | #12
        "Green top" is standard taping compound (USG), "Blue top" is lightweight topping compound.
        The awful thing is that beauty is mysterious as well as terrible. God and the devil are fighting there, and the battlefield is the heart of man.- Fyodor Dostoyevski
      4. Tyr | Jul 22, 2008 03:45am | #13
        Janet:
        Now all you have to do is 1)Figure out what "sistering" means, 2) Predrill 3/16" holes in the sistering material(2X4X24), 3)Have some 3" course thread drywall screws, 4) Slip the screws into the predrilled holes, 5)Get your DeWalt screwgun out and making sure the surfaces match on the stud and sistering material screw it to your stud--tight, 6)screw your "almost" 24" square gypboard (drywall, sheetrock, etc.), 7) fill the gap around the patch about 1/2 full from the bottom of the gap, 8) Let it dry for a day--shrinking and cracking but out of sight--out of mind, 9) Do numbers 7 & 8 again, 10) do number 8 again, 11) scrap off any high spots of dried mud (compound) and then 12) smear a layer of compound over the screw heads (tighten just below flush--don't tear paper on gypboard) 13) smear compound over gap area at least 3" wide all around, 14)unroll and cut just enough paper tape (no mesh) to make 4 lengths about 28" long, 15) bed the tape into the compound with your knife--length #2 can overlap #1 at the corners--just butter up the top surface of the tape, 16)smooth as neatly as possible then let it all dry--again. 17)now dry, notice filled screw heads have shrunk. 18) Scrape screwheads and filled gap off with your blade and do it all again--maybe even a third. Sand as evenly as possible (now you see why you scrape as much as you do--cough from sanded compound. Hopefully you have to match some texture on the surrounding wall. You might have a "stomped" texture which is the easiest IF you have the brush and a tub to dump some compound in--thin to malted milk consistency and prepare to get covered, everything remotely close to your patch needs to be covered with a drop cloth. Other textures can be bought in pressurized cans--like "knock down". After you spray that on you have to lightly drag a gypboard knife across the splatter--at just the right degree of dryness. Now the primer paint, drying time, finish coat, dry time, 2nd finish coat. Nobody will ever know and you can hire out as somebody who can fix things on a punchlist. :) Tyr
  5. JTC1 | Jul 21, 2008 03:39pm | #7
    >>is drywall always a little smaller than its stated dimensions?<< No. I have never measured the "pre-cut" pieces sold at the big boxes.  I usually keep some leftover pieces around from bigger jobs for patching purposes.
    >>Do I need to fill in the gap, and with what?<< I would fill the gap with setting compound - probably the 5 minute variety. Then tape and finish as usual.
    As others have said -- there are probably many gaps in your home that were this big already. Don't get worried about it.
    Jim
    deadmanmike | Jul 21, 2008 05:54pm | #8
    One other thing: If you're trying to use it to span a 24" OC stud bay, I'd sister up some scrap lumber to the studs and under the existing dw, to screw to.
  7. Jim_Allen | Jul 22, 2008 03:56am | #14
    I'd be thrilled that I didn't have to shave it a little to fit it in. Mud and tape...no problem.
    I saw that stack for the first time the other day and thought "man...I've had to buy a lot of full sheets many times for small patchs. those might come in handy some day".
Behind the Scenes of a Concrete Batch Plant
The batch plant is your partner in getting high-quality concrete on your job site.
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
  • Podcast 549: Members-only Aftershow—Patios vs. Decks
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
  • Strategies for Venting a Roof Valley
BOOKS, DVDs, & MERCH
Shop the Store
  • Pretty Good House
    Buy Now
    Buy Now
  • 2023 Tool Guide
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
