Garage door remote openers
Roger52 | Posted in General Discussion on February 13, 2007 11:56am
Hi Everyone, This is my first foray into a discussion group so please bear with me. I am a full time residential remodeler in the Milwaukee, WI greater area.
I recently purchased a duplex in which I occupy one half of. My garage door remotes for both doors barely work beyond 10 feet from the motor. The opener is a “Lift-A-Dor” unit by Genie. I purchased new remotes with still no improvement in the range, I also tried changing the codes with no noticable difference.
Is there any simple method to extend the range of the remote signal other than buying a whole new garage door opener??
  1. USAnigel | Feb 14, 2007 01:22am | #1
    Find the "pick up" wire and extend or re-position it.
  2. kate | Feb 14, 2007 02:02am | #2
    Welcome to BT - Aingel forgot to say that, but I know he really meant to.
    edited for typos -
    Edited 2/13/2007 6:08 pm ET by kate
      jagwah | Feb 14, 2007 02:14am | #4
      Welcome to BT!
      And to all youse guys... fill out your profile. We all like to know where everyone is coming from.
      Just might be a gravitational anomaly in your area that reduces garage door signals. You might in that case need to paint some Kavorite on the bottom of the garage door to aide in it's lift.
      Just MHO. 8)
  3. richpark | Feb 14, 2007 02:10am | #3
    I also had a problem with the range of a garage door opener.  The antenna was a single wire that dangled beneath the unit.  I read online, if there was a problem with interference, wrap the antenna wire around a pencil and form a pigtail.  This helped a great deal with this opener. Please keep in mind that I did this to a 1997 genie opener and things probably have changed since then.
    1. Roger52 | Feb 14, 2007 04:06am | #8
      Thanks Rich, Along with extending the wire, I also pigtailed it and it dramatically increased my range.
  4. alwaysoverbudget | Feb 14, 2007 03:35am | #5
    i've got 3 new sears lifts. one won't hardly open when your sitting in front of it. i took a pc of 14 ga. wire and spliced on the antenna. helped some,gets out about 35' now. larry
    1. Roger52 | Feb 14, 2007 04:03am | #7
      It worked!! I spliced on some 14 ga. solid copper wire, pigtailed it and voila, I've now got a 20' range. Thanks, Roger
  5. Stilletto | Feb 14, 2007 03:35am | #6
    Change out the top panel with one that has glass in it.
  6. precision | Feb 14, 2007 04:47am | #9
    Im glad you asked that question because I had a problem with the range on my remote also and the only answer the installer had for me except for playing with the direction of the antenna was that with the growth of remote controlled garage door openers over the years the company's have had to raise the amount of channels available to meet demand so that the remote codes don't overlap and that causes the signals to become weaker. so unless they change technology it will only get worst.  I don't know if this is true or its just BS from is sales rep to shut-up clients like me who complain about the reduction of range over the years. But it did make sense.  But I will try-out what some of the guys have mentioned about the 14gauge copper wire twisted like pigtail.
    thanks
  7. gtmtnbiker | Feb 14, 2007 06:12am | #10
    Another trick I read somewhere is to take your garage opener and put it right under your chin.  Your body then becomes a huge antenna.
    Try it, it works!
    At my house, my opener has a range of 35ft and I was able to extend the range another couple hundred of feet.
    No idea what type of effect it has on your body if you do this repeatedly.
    I can understand why a garage door opener usually has limited range for a couple of reasons:
         1. To make it more difficult for someone to drive by with some type of scanner to try to open your door.
         2. For you to see if there is any obstruction (e.g, little kid) in the door path.
Fine Homebuilding – April/May 2023, Issue #314
Find online articles on options for countertops, wood-boring bits, ductless heat pumps, tighter miters, fences, and much more.
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
  • Strategies for Venting a Roof Valley
  • Podcast 547: Basement Insulation, Historic Preservation Resources, and Shipping Container ADUs
  • Podcast 547: Members-only Aftershow—Fine Homebuilding House memories
BOOKS, DVDs, & MERCH
Shop the Store
  • Pretty Good House
    Buy Now
    Buy Now
    Buy Now
  • 2023 Tool Guide
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
