I have a garage door that will not open with the two remotes, new batteries are installed. The back of the opener mechanism has seven sliding pins (three position) but the remotes have only six. I might be off a number but the remote has one more than the opener. This is an older craftsman. How do I reset or reprogram this thing?
Nobody is as good as they seem, nobody is as bad as they seem either.
http://www.aaaremotes.com/lif63tran.html
Thank you, I think that is exactly what I needed. It is printed off and ready to go.Nobody is as good as they seem, nobody is as bad as they seem either.
You might want to consider upgrading to a rolling code transmitter/receiver system. Sears was selling one that was a real simple install -- plug in to an outlet and connect the pushbutton wires to the terminals.
