I am a bit clumsy on the computer as well as this site, can anyone point me in the right direction to find a past thread on painting garage floors. I welcome any suggestions or techniques as well.
“Did you see where that nail went? Its not sticking out of my head is it?”
i just did a small floor with the 2 part expoxy,that you can throw flecs into.looks nice and has held up real well for 8 days! lol i'm interested in this thread also as i have a 2500 ft rough floor to do. larry
You wouldn't be from St Leonard would you???
Nope, M'waukee Sconsin.
Is your garage being used for parking cars?
The client uses the garage mainly for storage and parking of one vehicle. There are some pocked areas of the concrete as well. My boss is trying to find a method for effectively filling these areas with as thin a coat as possible before painting. The home is probably built late 1940's and the garage may be a later addition.
For small patch areas most flooring contractors in our area use
epoxy and sand to fill and patch. let it cure then coat.
Typically an acid wash or shot blast (can rent) before coating to
open the pores of the concrete to allow the epoxy to bond fully.
Good luck!
Mclaren
Thanks for the info. Are you suggesting I mix fine grit sand with epoxy to fill small pock and divots in the floor? The acid wash is something we have done before. We have not had much success with filling or smoothing the surface.
LI,
That's a common fix in our area (mid-atlantic)
small batch of epoxy and sand (good quality, dried) mixed
and troweled over the voids and imperfections and let cure.
make sure the edges are feathered. then base coat w/ sand
broadcast. after it cures sweep up excess sand and topcoat. sometimes a
heavier coat near repair areas to help hide imperfections.
Mclaren
** may not be an option with the flake systems out there.
I'm thinking of just a straight epoxy (or urethane) coating.
Edited 3/20/2007 5:59 am ET by mclaren
http://www.miracote.com
Search this site for Miracote Repair Mortar III. It's squeeged or troweled on, perfect for fixing pitted or damaged ceement floors. Chase and epoxy fill any cracks. Put your saw cuts where needed, fill them flush with a polyurethane caulk.
One can then top that with one of their 100% solids epoxy (no smell) that has an infinite variety of colors, sheens, overlayments, underlayments, additives, dispersants, coagulants, whatever to effect a finish.
OR, one can top it with Miracote MPC, a acrylic fortified cementatious coating that can be sprayed, rolled, troweled, squeeged, hand smoothed, knocked down, knocked up, colored, overlaid, patterned, (on and on) all to your artistically inspired desires.
And then finish coat with several types of urethanes, glazes, and sealers - the last having an antislip microdust like pumice, Al oxide, or glass beads added so's you don't fall and break your azz.
The quality of these products are vastly superior to what you can pick up at the big boxes.
If you're gonna do it, do it right. I'm having to shot blast and clean up the previous joker of an owner's mess. My next house - if it has some HO applied ceement finish, will have the cost of removing and replacing any such mistake. So don't necessarily think doing a cheep garage floor paint to clean it up for selling will do wonders for the selling price.
I'm seeing a lot of advertising of these floor products to the DIY crowd. My experience is telling me the expertise offered by someone well schooled in the application techniques and nuances of the various products results in a better, lower cost application.
Mclaren,
Thanks for the return info. I will definitely investigate the products and techniques you and the other fellas mentioned. My employer will be quite pleased also to know there is a product to squeegee or roll out for pitting, etc.
This forum rocks! I always look forward to gleaning info and laughing at jokes that only tradesman seem to understand.
Look for Ardex products. They have surface preps that will do exactly what you need.
You might want to check out the forums on this site. They have one dedicated to garage floors.
http://www.garagejournal.com/
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
thanks for the link, it should help my research a good deal
