Garbage Disposer Switch
CJD | Posted in General Discussion on March 13, 2006 08:36am
Has anyone used the remote countertop garbage disposer switches? The only ones I know of are from In-Sink-Erator and WasteKing. I would appreciate any feedback on function and reliability.
In-Sink-Erator, pneumatic
http://www.insinkerator.com/isejsp/product/accessory.jsp?id=32&template=hhd
WasteKing, fiberoptic
http://www.wasteking.com/products/accessories/fiber_optic.htm
  1. peteshlagor | Mar 13, 2006 08:53pm | #1
    Yes, they're nice.
  2. stinger | Mar 13, 2006 09:06pm | #2
    We have used air switches on the last two kitchens, and are quite happy with the results.
    Allows a switch to be counter-mounted right next to the sink.  We place them just adjacent the far right corner.
    xxPaulCPxx | Mar 13, 2006 09:11pm | #3
    I luuuv mine.  I put it above the very narrow backsplash under the window over the sink.
    Also a CRX fanatic!
  4. nedly44 | Mar 13, 2006 10:46pm | #4
    I've used the air switch. it is great necause it can be on the countertop. no need to hide the switch under the sink or tear a wall open to mount it. however, you do need a hole in the countertop. switch is silent and reliable.
  5. Renoun | Mar 14, 2006 10:19am | #5
    The In-Sink-Erator has a second outlet for installing (especially retrofitting) a instant hot water tap. The hot water outlet cuts out when the disposal is on so no breakers get blown. Been meaning to get one so I can install a hot water tap I salvaged.
    1. CJD | Mar 14, 2006 05:05pm | #6
      Thanks all for the replies. Has anyone used the fiberoptic WasteKing switch? I am a little concerned over the membrane switch holding up.
        Gene_Davis | Mar 14, 2006 07:25pm | #7
        The air switches are the same kind used in hot tubs, spas, whirlpool tubs, etc.
        These switches are in heavy use in commercial facilities like day spas, health clubs, etc.  There is no reason to think that they are not durable enough for home use in a sink grinder setup.
        1. CJD | Mar 15, 2006 12:54am | #8
          I agree that the pneumatic switches are fine. The In-Sink-Erator has been around a while. I am concerned over the membrane switch that is on the fiberoptic WasteKing unit and have never seen one except on the Web.
Rescuing Old Hardware
Whether it’s already in your house or picked up at a flea market, vintage hardware almost always needs help.
  • Picture-Perfect Pergola
