Gas range burners plugged by soap?
joeyh | Posted in General Discussion on April 12, 2007 08:42am
Okay, this may be a little off topic for this forum, but I can’t resist tapping into the collective wisdom of all you Breaktimers.
Our cleaning lady cleaned our gas range stovetop and now the burners won’t ignite. This is an electric start model. I’m assuming some soap is gumming up the works, but I don’t know how to unplug things. Has anyone had this trouble, and have you found a solution?
Thanks in advance…
  1. Teni | Apr 12, 2007 09:24pm | #1
    I found some good advice at  http://www.appliance411.com/forum/
    Are the little caps on crooked?
    1. joeyh | Apr 12, 2007 09:49pm | #2
      Thanks for the link. I'll try there too.
      I'm not sure what little caps you mean.
  2. smslaw | Apr 12, 2007 11:18pm | #3
    It has happened to us.  We just  use a match to light it.  The moisture dries out and then you are in business.  I assume whatever is gumming up the works is mostly water.
    Edited 4/12/2007 4:19 pm ET by smslaw
    1. joeyh | Apr 12, 2007 11:28pm | #4
      Ha! Easy solution. Thanks so much.
