I am going to attempt to build a glass block shower and I need some advice from someone with experience. It will be in the corner of a room and the existing wall surfaces will be tiled and I plan to build the other two walls from glass block. I really want to learn how to do this from start to finish and any help would be greatly appreciated!!!! I need the correct sequence of events starting at the shower pan and going all the way through. If anyone knows of a good website containing this information that would be great also!! I just want to make sure I do this properly; professional look,no leaks! Thanks!
Duey
They covered how to in a past issue of Fine homebuilding.. I'll look thru my back issues....
http://www.pittsburghcorning.com/literature/gb-230.pdf
Edited 1/22/2005 2:08 pm ET by Don From Utah
Have a look at http://johnbridge.com/vbulletin/index.php
The section they call the 'liberry' has a lot of from the ground up information.
I will check out the sites mentioned above! Also curious to know which issue of FHB, as I have been a subscriber for awhile. I'll try to find it in my stack! Thanks!!
Duey
