glue/sealant used for installing transom
toycept | Posted in Construction Techniques on September 20, 2006 04:18am
I’m installing a transom above a door. All wood is new wood. Can someone suggest a tough glue/sealant that should be used between the two mating surfaces (surface of the transom frame and the recess of the door frame its fitting into)?
Thank you.
Pressure Washing Made Portable
This electric pressure washer is compact, lightweight, and easy to maneuver.
  • Tall Deck on a Sloped Lot
  • Making and Installing Wood Wall Paneling
  • Hand-Sanding Hack
